TIMING OUT BAD..pls HLP
ok well i pullled plug and got cyl up and can drop dizzy in any way...i know its supposed to pointed at number one butwhich was is first plug supposed to be pointing??and you said point my light at it but i cant use my light til i get it to start correct??
here....read this
https://mustangforums.com/forum/5-0l-1979-1995-mustang/293134-how-to-properly-stab-your-distributor.html
if you have trouble from there let us know. that should get you in the right area.
and yes you point the light at your H balancer after you get everything running.
you need to have the rotor point directly to the #1 plug wire on the cap. if not you're "one tooth off" maybe more
once you believe you are at TDC make sure your balancer is pointed at 0*
strap everything down, unplug your spout and fire it up
thats when you time it.
then yes proceed to unplug spount and fire it up. time it and you should be GTG.
Thanx for all the help..So i put the HAR on 0* on comp stroke...i put the dist matching the line on base w/ edge of casting--0*--made sure my rotor was pointing at #1 plug...bolted it all and clamped cap, pulled spount and tried to crank but nothing...i believe yall have told me everything there is to know..thats what i got from it...where did i go wrong??
it acts like it has no fire but pulled plugs it does..when it turns over its like real fast and doesnt even try...every once in a while if i give it some gas when i let off of it, it sounds like it hits like once maybe twice but never starts...plugs goin right and coil hooked up...
