Are These Numbers Low-Trick Flow Top End Kit
#34
My setup was never tuned just dyno'd, dyno'd it at mike ward racing in reynoldsburg. He wants about $500 for a tune/chip which i might do in the future but for now its runnin pretty rich/safe so im happy with it.
#37
Thats what you have to expect when you buy a TrickFlow OTS kit. Theyre heads arent bad and alot of ppl run the twisted wedge heads on a ton of different combo's. Where people make the power is when they go with the different cam and intake. TF does make a decent intake though.
#38
ya its a 150 shot NOS wet plate kit, hooked with a window/tps switch and the digital 6 doing the timing retard. When i took it to the dyno i had 3 pulls for 85$ w/ A/F ratio, 1st was motor, second with nos we thought the tires spun on the second because it reved super quick once the shot kicked in.
They then center strapped the rear axle and tried it again on the 3rd run and it turned out to be my King Cobra clutch was just spinin right through the 150shot. It was pretty wicked if i say so myself =D
I talked to the guy who dyno'd it, he said hed give me a discount the next time after i fixed my clutch and what not so i'll eventually have the numbers with the 150shot
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
Choppertwo
08-18-2015 02:21 PM
