just wanna run crank waterpump and alt pulley how do i??
This is how I've had my belt routed for 4 years...even the same belt...just used a ribbed tensioner.
I think to do it without the PS pump you may need to relocate the tensioner a little bit and it may work some how.
real nice pic in my sig. i have a standard rotation water pump. the alt. has a rod with heim joints on the end that allow me to use the alt as my belt tensioner. for those wondering why the alt is on the driver's side its because i used this same acc. configuration when i had my vortech supercharger before i got "the twins"
your going to have to measure yourself. take a wire, not string because it will stretch and trace the path the belt would.
http://www.tamparacing.com/forums/fo...ml#post4150019 here is a link with part numbers
