Which injectors are these?
Old 12-10-2008, 03:44 PM
justhereforinfo
justhereforinfo's Avatar
Default Which injectors are these?
I bought the car with these injectors so I dont know for sure what they are. I thought he said they were 19's, but after installing my wideband, well I'm running in the 10's at wot with gt40p heads and a mild cam.
Is this a stock MAF?
I've noticed the idle is not steady and it stalled out once. The afr bounces from 13-18 at idle. Should I get a larger diameter MAF calibrated for whatever size injector these are or recalibrate the stocker?
The Tech article about injector color/size needs to be update.
justhereforinfo is offline
Old 12-10-2008, 03:59 PM
Portmaster
Portmaster's Avatar
24lb I beleive
Portmaster is offline
Old 12-10-2008, 04:25 PM
justhereforinfo
Originally Posted by Portmaster
24lb I beleive
Thats what I'm guessing, but I've seen 24s for sale that were grey. Is it true that the water temp sensor can make you run rich? Cause I cracked mine and jb welded it back together.
Old 12-10-2008, 04:33 PM
jtmustang
jtmustang's Avatar
those are 24 lb injectors and just buy a new sensor there not that much
jtmustang is offline
Old 12-10-2008, 04:35 PM
uedlose
uedlose's Avatar
looks like 24s to me I have had a few sets that color and they where 24s. yes the temp sensor for the EEC if bad can make the car run rich
uedlose is offline
Old 12-10-2008, 06:17 PM
FORD TOUGH
FORD TOUGH's Avatar
yes the coolant temp sensor can make the engine run rich. If it thinks the engine is colder than its it will give it more fuel. I have heard that the blues injectors are 24's but I don't know if it is true.
FORD TOUGH is offline
Old 12-10-2008, 06:21 PM
FORD TOUGH
FORD TOUGH's Avatar
I have a 5.9 out of a dodge truck sitting in the garage. It has gray injectors. I hope they are 24's. They plug up like a ford.
Old 12-10-2008, 09:08 PM
Milton
Milton's Avatar
id say 24's. the stock 19s are an orange color
Milton is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Dathan
10-05-2015 05:52 AM
MacSerio
09-27-2015 01:05 PM
mltdwn12
09-23-2015 08:54 AM
Quick Reply: Which injectors are these?
