Now What...
Old 12-26-2008, 10:38 AM
Jon2887
Jon2887's Avatar
Unhappy Now What...
I posted a thread a few days ago about my troubles with my mustang, and how I thought I had broke my clutch cable. So I just replaced my clutch cable today, and its still acting the same way.
When I push down on the clutch pedal it makes a loud popping/ breaking noise, and then goes straight to the floor very quickly. Sometimes it'll make the breaking noise 2 or 3 times before hitting the floor. I cant put the car in gear when its on, only when its off. I can put it in gear when the clutch pedal isn't pushed in.
So I'm not sure what to do? Any help would be great.
84 mustang gt carb
Jon2887 is offline
Old 12-26-2008, 11:01 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
if you are running the stock clutch quadrant you could have broken it. that maybe what all the cracking noises are. that also could explain why your clutch is not disenguaging.
FivePointOhh is offline
Old 12-26-2008, 12:11 PM
AdderMk2
Banned
AdderMk2's Avatar
my thoughts exactly.. check the quadrant under the dash over the gas pedal... heres a few pics of what to look for.
And you should replace it with an aftermarket piece, like this...
AdderMk2 is offline
Old 12-26-2008, 12:59 PM
Jon2887
Jon2887's Avatar
Default thanks
ok cool ill check it out. I hate being under the dash though, things get really tight down there.
Jon2887 is offline
Old 12-26-2008, 01:27 PM
calfroper_06
calfroper_06's Avatar
LOL, yeah not much room, remove the seat and laydown a piece of foam over the seat bolts. It makes it a little move comfortable to work on
calfroper_06 is offline
Old 12-26-2008, 02:00 PM
aode08
aode08's Avatar
Funny, I just put one of those on a 5.0 4 days ago.
While your under there, check your accelerator pedal cable for play as well.
If the seat has to come out, its a good idea to spray penetrating oil on the threads under the vehicle's chassis.
Please let us know what you found.
aode08 is offline
Old 12-26-2008, 02:26 PM
FivePointOhh
in limbo
ahhhh adder used a triple hook...! lol. hasnt everone being saying lately those have been breaking cables?
i need to change mine out, mine is creaking right now :-/
Old 12-26-2008, 03:40 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
my jegs one looks completely different
mjr46 is offline
Old 12-26-2008, 03:48 PM
FivePointOhh
in limbo
You bought yours chuck? i though you widdled aluminum with your fingernails?
Old 12-28-2008, 12:47 AM
AdderMk2
Banned
AdderMk2's Avatar
they do break cables.... and the cable im currently using WAS a broken cable... I crimped on a new cable stop and cut it shorter, and I use the last hook now
AdderMk2 is offline
Quick Reply: Now What...
