Base Idle Reset and Car won't start again
Old 12-27-2008, 09:38 PM
92TripleBlack5.0Vert
92TripleBlack5.0Vert's Avatar
Default Base Idle Reset and Car won't start again
I just recently finished repairing a few electrical problems and the car was not idling properly, so I did the base idle reset, adjusted my idle to about 750rpms with the IAC disconnected car running, and then I shut it off, reconnect the IAC and wait 20 seconds,then the car doesn't start. The only way I have had any luck starting it is by resetting the computer, and pumping the throttle to get it started. When I do that it starts up fine every time I shut it off, unless I attempt the base idle reset. Who knows whats happening here. All I can think of is bad IAC, but I'd hate to go buy the autozone junk if mine is fine. Thanks
92TripleBlack5.0Vert is offline
Old 12-27-2008, 10:09 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
did you have it running fine before you tried setting your idle or was this an attempt to fix your idle?
FivePointOhh is offline
Old 12-27-2008, 10:13 PM
the car was not running fine, it started up, and surged and when I took it for a ride, it stalled out at low revs, which is why I adjusted the idle. When I went to plug the IAC back in, after adjusting it with the iac disconnected, thats when it wouldnt start. It hasn't run in about 8 weeks before this.
Old 12-27-2008, 10:17 PM
FivePointOhh
in limbo
setting the idle screw only sets where you want it to idle at, it wont fix surging.
check your tps voltage is between .6 and 1.01 on the green wire with key in the on position. get it started up again and verify base timing with spout out then set base idle after those things are done. if you are still having issues you need to run koeo/koer self tests to find out if you have codes and also check for vacuum leaks.
LUK
Old 12-27-2008, 10:21 PM
I am aware, I have timing at 10 degrees, tps voltage on the green wire is .8, also I have no vacuum leaks, it ran fine before it sat, nothing has been changed. I do need to run koeo/koer for codes
Old 12-27-2008, 10:41 PM
FORD TOUGH
FORD TOUGH's Avatar
Are you sure there are not any vacuum leaks.
FORD TOUGH is offline
Old 12-27-2008, 10:43 PM
no vacuum leaks. pretty straight forward. I had it running fine without surging. Just would stall at low speeds when driving. Im positive theres no vac. leaks x2
Old 03-02-2009, 07:52 PM
rickinfl
rickinfl's Avatar
hey have you tried the ignition switch? your car will do weird things if it is going bad. it had my car blowing flames out the back.
rickinfl is offline
djbigskrilla
09-20-2022 01:04 AM
msavoia23
12
07-07-2018 12:08 PM
KEM Motorworks
08-14-2015 10:13 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Base Idle Reset and Car won't start again
