rear 5 lug conversion
Old 12-28-2008, 08:44 AM
symonds86
symonds86's Avatar
Default rear 5 lug conversion
i swapped my axles and all the bake parts from a 95 stang to my 88 but i have one problem.when i try to bolt up the caliper bracket it hits the rear of the rotor. anyone had this issue? i have the c clips on and the center pin in so the axles are in the right place. any help would be great
symonds86 is offline
Old 12-28-2008, 08:51 AM
Timspony
SVT Section Moderator
Timspony's Avatar
the '95 axles are 3/4" longer then your '88 8.8" rear & will not work! ...if that's what your attempting...
Timspony is offline
Old 12-28-2008, 10:47 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
either use the left side I believe of a ford ranger axle set up or buy 5 lug axles for a fox
mjr46 is offline
Old 12-28-2008, 11:47 AM
sjd3021
sjd3021's Avatar
the 95 axles WILL WORK
sjd3021 is offline
Old 12-28-2008, 12:16 PM
symonds86
symonds86's Avatar
i read somewhere they would it just made the width wider, and the wider axles make it perfect for my 10.5 bullits to fit
Old 12-28-2008, 12:17 PM
Timspony
Timspony's Avatar
In a Fox '88 8.8" rear axle? ....I understand that a "complete" '95 rear will work, bolted in as a whole, but not the case to just unbolt axles & pop into a Fox 8.8"....as I stated ^^^ axles 3/4" longer!
Timspony is offline
Old 12-28-2008, 01:02 PM
sjd3021
sjd3021's Avatar
i have a 93 cobra that used to have 4 lug rear disc. the axles were 3/4 inch longer. i switched to 5 lug w/ the shorter axles <fox length>. the 95 axles will work in the older housing w/ all the matching hardware
sjd3021 is offline
Old 12-28-2008, 01:12 PM
sjd3021
sjd3021's Avatar
try the search, if i remember someone had a problem similar to you. i think they used spacers or something
sjd3021 is offline
Old 12-28-2008, 02:09 PM
symonds86
symonds86's Avatar
i read that they work because the axle housings are the same length, but the axles are longer in order to make room for rear rotors i could be wrong though, thanks for all the help so far
11-10-2015 11:39 AM
Matt's 95 Stang
10-05-2015 07:16 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
lincolnshibuya
09-24-2015 10:46 PM
09-16-2015 07:53 PM
Quick Reply: rear 5 lug conversion
