moving the battery
not a problem, hope it works out with you. in further reference, i do know that advanced, autozone, or napa carry sealed battery boxes as well for $9.98. i just havent bought one because i didnt know that i actually needed one until now, so look into that if you want a cheaper way tpo relocate it!! good luck, btw nice t-top. id love to have one.
it is mass air now i have checked for vac leaks didnt find any it was running fine and the i went to drive it around the block and the clutch cable broke and i shut the car off and it wouldnt start again it just turns over
If you want it to pass tech at a NHRA drag strip. The switch at the back of the car must kill the engine when thown to OFF.
This requires power wire to feed EVERYTHING but the starter to run to the back of the car. It'll be fused.
Now the starter wire should be dead at all times except during cranking. All you need to to there is place the solenoid at the back of the car.
Not required but the best and safest way for a rear mounted battery.
