Steering Shaft help
Old 01-11-2009, 11:37 AM
cholericfc
cholericfc's Avatar
Default Steering Shaft help
How hard is it to replace a steering shaft?
I'm doing it out of my home, and at the same time, I'm replacing the steering rack, tie rods, bushings, and I'm going to need an alignment on a car already in NEED of one.
dangerous dealing with the shaft?
This and rebuilding an axle are the only things I haven't done on a car....
cholericfc is offline
Old 01-11-2009, 01:27 PM
93 LX FiveO
93 LX FiveO's Avatar
the shaft is quite simple to replace.
just make sure the steering wheel does not lock while you're unbolting it
depending on your headers you may also run into clearence issues.
i have the flaming river low-profile design shaft and the only real problem was aligning the shaft so that it wouldnt bind on itself. once i resolved that, i found 2 bolts hitting my header (unequal bbk shorties). a quick grind and everything was smooth.
be very careful with the hard lines off the rack. they bend/break very easily.
goodluck, need help shoot me a pm.
93 LX FiveO is offline
Old 01-11-2009, 01:43 PM
cholericfc
cholericfc's Avatar
I plan on getting a MM steering shaft... and the rack is just a kit from 50resto bc i'm sticking with power steering. I'm avoiding flaming river with this car.
Old 01-11-2009, 01:57 PM
Catchpole
Catchpole's Avatar
As already said the swap itself is easy, gettin to the bolts and clearence is the hard part
Catchpole is offline
Old 01-11-2009, 04:28 PM
cholericfc
cholericfc's Avatar
MY headers are BBK shorties.. just in case anyone has that set up....
Old 01-11-2009, 05:18 PM
Hung Like a Stang
Hung Like a Stang's Avatar
yeah, its easy. just be sure you tie the steering wheel in place. If it free-wheels you could damage your clockspring if you have an airbag.
Hung Like a Stang is offline
CS2007
06-25-2019 09:45 PM
bradleyb
11-27-2015 07:50 PM
ChampInSD
10-02-2015 04:55 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
stark777
09-21-2015 12:46 PM
Quick Reply: Steering Shaft help
