Im losing patience!!!
Old 02-10-2009, 07:25 AM
  #21
kay15ace
kay15ace's Avatar
Bump.....
kay15ace is offline
Old 02-10-2009, 09:03 AM
  #22
94Yellow50
94Yellow50's Avatar
if he used an OBD-II scanner and hooked it to the port under the dash, that would be why it didnt communicate. your car isnt OBD-II. Yes, the plug is there, but not hooked up to read codes. you have to do the KOER/KOEO test. joel has a very good right up on it.
94Yellow50 is offline
Old 02-10-2009, 09:17 AM
  #23
kay15ace
kay15ace's Avatar
Is my car compatible with an OBD-I scanner? I don't know if he was either using a OBD I-II scanner or an OBD II scanner.
kay15ace is offline
Old 02-10-2009, 09:27 AM
  #24
Slo5oh
Banned
Slo5oh's Avatar
Ill throw my suspicion into here. Plug wires.
Slo5oh is offline
Old 02-17-2009, 07:17 AM
  #25
kay15ace
kay15ace's Avatar
Sooooo I replaced the spark plug wires, cap and rotor. When I fired up my car the battery light stayed on for some reason I turned on all of my power accesories by my volt meter remained the same. Later that night I fired up my car again and the light still stayed on so I decided to drive it around a backroad. I was going about 35-40 and then I down shifted, as soon I did the light went away. I drove it to class this morning only to have it still continue this problem...
kay15ace is offline
Old 02-17-2009, 07:55 AM
  #26
ewgoetz
ewgoetz's Avatar
Sounds like ya got a electrical issue somewhere or a loose connector. Go back and make sure when u did the tune up you didnt loosen any wires/connectors. You cna do something like that very easily with out noticing.
ewgoetz is offline
Old 02-17-2009, 10:03 AM
  #27
kay15ace
kay15ace's Avatar
Where should I look for a loose wire? Yesterday was the first time the battery light came on. Should I look around the alternator?
kay15ace is offline
Old 02-17-2009, 01:52 PM
  #28
kay15ace
kay15ace's Avatar
Still need help
kay15ace is offline
Old 02-19-2009, 07:27 AM
  #29
kay15ace
kay15ace's Avatar
Bump.....
kay15ace is offline
Old 02-19-2009, 12:40 PM
  #30
Pony 5.0
Pony 5.0's Avatar
Start with the ECU ground. It is the black looped wire that is attached to the battery ground cable. See if there is any corrosion or rust that could be preventing a good ground where the wire meets the chassis. Also look at the main ground wire from the back of the driver's side cylinder head to the firewall.
Pony 5.0 is offline
Quick Reply: Im losing patience!!!
