timing -tps-idle adjustment???
Old 01-20-2009, 04:07 AM
ponyboy302
ponyboy302's Avatar
Default timing -tps-idle adjustment???
ok maybe a stupid question i dont know ..
i read that idle adjustment is made with the throttle body i assume with the tps ???
whats the differance between setting the idle with the timing and the tps .. is there any connection ?? should the timing be set at a certain degree before the tps is set ? would it make a differance if the timing was at 12 or 14 when setting the tps ??
i apologize if i have no idea what im talking about lol.. in need of a lesson : o)
ponyboy302 is offline
Old 01-20-2009, 06:42 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
What are you trying to accomplish?
PRO50SC is offline
Old 01-20-2009, 07:01 AM
Joel5.0
Joel5.0's Avatar
Base Idle Reset Procedure .... TPS is not adjustable, as long as it falls within the .5 - 1.19 vdc "no failure code generated" window...... it will work. LUK
Joel5.0 is offline
Old 01-20-2009, 02:15 PM
ponyboy302
ponyboy302's Avatar
hmm didnt really have a plan to accomplish , the car runs fine im just trying to learn this stuff for myself .
i just thought i read you can adjust idle with the throttle body and i always thought idle was set with the timing , you raise the timing you will idle higher no ?
Old 01-20-2009, 02:33 PM
Joel5.0
Joel5.0's Avatar
Nope.... the idle will automatically be compensated back to its level via the Idle Air Control (IAC) actuator.
Joel5.0 is offline
Old 02-07-2009, 02:06 PM
84 Bullitt Builder
84 Bullitt Builder's Avatar
Okay, silly question. How do I test the range of the tps? Which wire is which for volt meter?
84 Bullitt Builder is offline
Old 02-07-2009, 04:21 PM
luckythirteen13
luckythirteen13's Avatar
the green one.
luckythirteen13 is offline
Pyrate Dave
09-10-2015 07:30 PM
DoctorScary
09-09-2015 07:53 AM
RWHEELS
09-05-2015 03:42 PM
raleigh05GTO
09-04-2015 07:09 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: timing -tps-idle adjustment???
