roller and non roller blocks
What are the physical differences in the the 2 exactly? Are the lifter bores taller to accommidate the roller lifters? I know how to use a roller cam in a non roller block so don't tell me that plz.
OOOOOrrrrrrr I can buy a $265 comp cams thumper retrofit cam, which sound bad *** but I havn't seen anyone use it, and drill and tap the block for the spider tray and run regular roller lifters and pushrods .
I think I am gonna just buy a $100 lunati flat tappet cam and be done with it.
292 duration with .512 lift and 110 LSA
Yea and they are more expensive. I can get the same performance from a normal flat tappet cam. The lunati cam I was looking at has the same specs as the comp cam you showed me mjr except it has longer duration on both intake and exhaust.
comp
http://store.summitracing.com/partde...3&autoview=sku
lunati
http://store.summitracing.com/partde...1&autoview=sku
comp
lunati
Matt's 95 Stang
10-05-2015 07:16 AM
