Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
351c heads
Old Sep 29, 2015 | 06:46 AM
mustangheaven's Avatar
mustangheaven
Default 351c heads
Hi, will 1973 mustang 351c 2V heads/intake fit on a 1970 315c block that had 4v heads? Thanks
Old Sep 29, 2015 | 06:47 AM
mustangheaven
opps meant 351 not 315
Old Sep 30, 2015 | 12:12 AM
jimkaray's Avatar
jimkaray
It will work. If this is not going to be a complete rebuild I'd also check into what compression ratio you will end up with. There should be some swap comparison charts around if you search the web.
Old Jan 3, 2016 | 11:20 AM
Richard1916's Avatar
Richard1916
Your compression ratio will depend what your short block originally had open chamber heads or closed chamber, and what cc heads you have to put on it. BEWARE i have run into a lot of 351C head with cracks in them check accordingly.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
kevsgt
Oct 9, 2015 10:12 PM
mustangheaven
Oct 7, 2015 10:23 AM
Drastang
Sep 30, 2015 03:48 AM
mustangheaven
Sep 29, 2015 11:00 AM
