steering issue?
Old 01-24-2009, 11:43 AM
LesteR723
LesteR723's Avatar
Default steering issue?
I have been having an issue with my steering lately, it happens at various speeds and it only happens intermittently. when i am driving straight occasionally the steering will go numb momentarily then start to pull to the left or right (not either way consistently) and when i am cornering or turning and the wheel is being held still, the car will not travel at a consistent angle, and the car will not straighten the wheel for me, i have to literally push it back. I have had the car for a few months before this started happening. The power steering fluid was slightly low, and i topped it off to no avail. Anyone have any ideas?
LesteR723 is offline
Old 01-24-2009, 11:48 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
just give your front suspension a good look over. checkfor bad tie rods, ball joint, wheel bearings. im not sure what would cause such a inconsistency in steering. weird...
FivePointOhh is offline
Old 01-24-2009, 04:31 PM
94StinkinLincoln
94StinkinLincoln's Avatar
something has to be loose or really worn, i could see if it was a quick jerk like bump steer, but that sounds much worse. it goes at random in to the left or right? does it go a different direction when u turn hard left or right- the direction it wanders to?
94StinkinLincoln is offline
Old 01-24-2009, 05:41 PM
mustang86lxconv
mustang86lxconv's Avatar
I would check youstruts and strut plates.. if they are out of wack , this may happen. had a similar problem wiht my 86 and after replacing them everything is fine
mustang86lxconv is offline
Old 01-26-2009, 09:13 AM
LesteR723
LesteR723's Avatar
I'll be sure to go out and check those things when i get home from college this weekend.
i thought it may have been something that had worn out but it happened so quickly that i was at a loss for a problem. i actually have a bad terminal i have to replace before i can go drive it again and play around with it and jerk real hard, but after i replace that i will let you know.
I know for a fact i have bad shocks and struts. I will definitely check those out... if the strut plates are bad should i just look for a junk yard replacement?
Old 01-26-2009, 03:15 PM
94StinkinLincoln
If you need stock struts and shocks, i have my stock one laying around still. 117k miles on them though... pm me if you want em.
Old 01-26-2009, 05:31 PM
LesteR723
LesteR723's Avatar
My car is lowered, i will need adjustables or i will just blow them out again
Old 01-29-2009, 09:45 PM
Detroit_Muscle
Detroit_Muscle's Avatar
That sucks. I had a simular problem when i lowered my car and replaced my tie rods and ball joints. That was the problem car drives great now.
Detroit_Muscle is offline
Old 02-01-2009, 09:37 PM
LesteR723
LesteR723's Avatar
yeah the only strange thing about this one is that it has been lowered since i bought it, and it JUSt started doing it
Old 02-01-2009, 09:46 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
check tie rods, inner and outer and ball joints for loosness/ worn out, if all suspension stuff is tight, rack may be bad
mjr46 is offline
Quick Reply: steering issue?
