best intake manifold for street/strip 5.0
Old 01-28-2009, 02:05 AM
stockmonster
stockmonster's Avatar
Default best intake manifold for street/strip 5.0
what do you think is the best street-strip intake manifold for a 5.0. and when i say best i mean power
stockmonster is offline
Old 01-28-2009, 09:42 AM
PJC Racing
PJC Racing's Avatar
Depends on what the goal is and the supporting engine modifications.
PJC Racing is offline
Old 01-28-2009, 10:31 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
as PJC says....first define what your goal is
mjr46 is offline
Old 01-28-2009, 11:05 AM
kweb288
kweb288's Avatar
are you going na, nitrous, turbo, sc, going stock 302? heads? stroker?
kweb288 is offline
Old 01-29-2009, 11:20 AM
flyin ryan
flyin ryan's Avatar
holley systemax 2 flows allot and is well liked on forced induction cars that don't want a short runner box type but it lacks the lower torque that tfs and gt40 type intakes give you
flyin ryan is offline
Old 01-29-2009, 08:00 PM
5.0kopkar
5.0kopkar's Avatar
I'm personally a big fan of the GT40 intakes (Explorer, Cobra, etc.,). They seem to provide the best range of torque and horsepower. Yes, others will have more top end, but the GT40s have really good low and mid range (which is were most cars are driven).
5.0kopkar is offline
Old 01-30-2009, 12:11 AM
stockmonster
ok i have completely stock lower half stock heads, i am na right now but plan on adding nitrious. so if that helps. but lets talk about the explorer intake.... i have heard this from several places and friends with 5.0s, that port an explorer manifold upper and lower it can compete with expensive aftermarket manifolds. can it handle nitrious and potentially up to 400 hp? let me know
Old 01-30-2009, 05:55 AM
Timspony
SVT Section Moderator
Timspony's Avatar
Cobra intake...
Timspony is offline
Old 01-31-2009, 01:42 AM
stockmonster
i hear a cobra intake can only safely handle up to 350? true false? if it can handle 400 thats which way i porobaly lean...isnt the cobra intake comparible to the explorer intake?
Old 01-31-2009, 07:18 AM
Portmaster
Portmaster's Avatar
If you have a stock block, stock heads and plan on running nitrous only don't waste your money on an intake. Buy a nitrous system that has a wet plate that bolts between the upper and lower intake. That way it will bypass the T-body, upper intake and shoot that Oxygen, Nitrogen and fuel within just a few inches of the cyl head opening. Your heads will be the weak link in this equation and you can put more through the stock ports than the engine can stand. Here ya go
http://store.summitracing.com/partde...82+4294906920+
Portmaster is offline
Quick Reply: best intake manifold for street/strip 5.0
