5spd hard to get in/out of gear....
Old 02-01-2009, 07:37 PM
jagman454
jagman454's Avatar
Default 5spd hard to get in/out of gear....
its a T-5 WC thats just recently been rebuilt all new syncro's and everything.....when Ever its I first start to drive the car from starting it up its very difficult to shift.... but as soon as my car gets up to operational temp it seems to shift "ok" it shouldn't be doing this right?
thanks
jagman454 is offline
Old 02-01-2009, 07:51 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
it shouldn't do that, I'd make sure clutch adjustment is okay and proper fluid was used= atf/ dextron III
mjr46 is offline
Old 02-01-2009, 11:31 PM
chevykilla89
chevykilla89's Avatar
Yep use ATF someguys use gear oil and they have the cold shift problems....
chevykilla89 is offline
Old 02-03-2009, 06:28 AM
jagman454
jagman454's Avatar
yea i used ATF.... i guess I'll keep messing with the adjustment and see where that gets me thanks
Old 02-03-2009, 08:31 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
have you messed with any of your clutch adjustments? you may have used atf but does it say what types of trans they are for? when i went to autozone to get the dexIII i looked at the atf and i found one brand there that was not for ford tansmissions.
FivePointOhh is offline
Old 02-03-2009, 09:45 AM
red87
red87's Avatar
did they reinstall the shifter bushing after it was rebuilt?
red87 is offline
Old 02-03-2009, 10:42 AM
FivePointOhh
in limbo
? do you mean the plastic top hot that goes into the shift block?
Old 02-03-2009, 11:01 AM
red87
red87's Avatar
yes the bottom of the shifter goes into it. i had my tranny rebuilt tooand the bushing was never reinstalled when the tranny was put back in and caused similiar problems to the ones listed
red87 is offline
Old 02-03-2009, 11:09 AM
FivePointOhh
in limbo
....i dont think so. it doesnt assist with shifting. just eliminates some vibration and keep the shifter handle from wiggling around like crazy. it wont increase the difficulty of putting it into gear, just harder to find the gear for a newb.
Old 02-03-2009, 11:18 AM
red87
red87's Avatar
just trying to help
red87 is offline
Quick Reply: 5spd hard to get in/out of gear....
