New Calipers leak
Old 02-10-2009, 05:55 AM
zeekstr
zeekstr's Avatar
Default New Calipers leak
Just put on 73mm calipers on. While bleeding them, they were gushing out fluid
where the brake line bolts on. Everything looks OK.
Do I need to get the correct width shim (washer) between the caliper and the
bolt?
zeekstr is offline
Old 02-10-2009, 10:50 AM
.boB
.boB's Avatar
Did you re-use the old copper washers? Did you use two of those copper washers?
.boB is offline
Old 02-10-2009, 11:38 AM
Timspony
SVT Section Moderator
Timspony's Avatar
...need that cooper washer! get new ones as stated ^^^^
Timspony is offline
Old 02-10-2009, 11:42 AM
zeekstr
zeekstr's Avatar
10/4. Thanks.
zeekstr is offline
Old 02-10-2009, 01:09 PM
HACKGT350
HACKGT350's Avatar
yup make sure you are using new copper washers. one on each side of the connection and make sure that they arent doubled up because i know it happens a lot
HACKGT350 is offline
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
jerrytubes
10-23-2015 12:11 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: New Calipers leak
