heads
Old 02-23-2009, 02:32 PM
lx5.0
lx5.0's Avatar
Default heads
are the Procomp Motorsport's 3037 SBFord Aluminum Cylinder Heads good
lx5.0 is offline
Old 02-23-2009, 03:09 PM
SonicBlueFiveSlow
SonicBlueFiveSlow's Avatar
I think most everyone on here will tell you that procomps are junk.
SonicBlueFiveSlow is offline
Old 02-23-2009, 03:37 PM
woodsy
woodsy's Avatar
I have had several sets here at the shop, you can keep them
woodsy is offline
Old 02-23-2009, 03:41 PM
BlessedHellride
BlessedHellride's Avatar
I have a set of Pro Comps on my turd. It holds its own.
BlessedHellride is offline
Old 02-23-2009, 04:59 PM
Portmaster
Portmaster's Avatar
I don't like them and wouldn't put them on my own stuff. I do know guys that run them on the street and they think they are OK. They are hard to beat for 500-600 dollars off of ebay. I rather have them than the E7's
Portmaster is offline
Old 02-23-2009, 05:04 PM
woodsy
woodsy's Avatar
When they drop a valve, dont be shocked. Cheapest possible valvetrain components are used.
woodsy is offline
Old 02-23-2009, 05:56 PM
OneFine89Mustang
OneFine89Mustang's Avatar
just invest in some afr heads, can't go worng
OneFine89Mustang is offline
Old 02-23-2009, 06:05 PM
BlessedHellride
Not to mention the Pro Comp 1.6 Roller Rockers I have on there also huh. I can't wait for this thing to explode!!!!
Old 02-23-2009, 06:07 PM
BlessedHellride
I haven't seen a brand/make of engine that hasn't dropped a valve at some point. When these engines turn those kind of rpms, bad things tend to happen. You, as an engine builder can agree to that I'm sure.
Old 02-23-2009, 06:31 PM
woodsy
woodsy's Avatar
If you need to justify the purchase of pro comp heads and rockers, thats fine, but the chances of yanking the valve tip off or through the cheap stamped retainers are 1000 times greater when using the cheapest soft chinese steel on the planet as compared to real machined steel. To deny the valvetrain used in pro comps is junk and the bearings used in the rockers are not chinese is naive. So if you like to play odds thats fine, but I wouldnt do it on my own stuff or a paying customer, thats my take, if a guy wants to use them, by all means. So back to the original questions, Are they good heads? No there not really very good at all.
woodsy is offline
Quick Reply: heads
