2 questions
2 questions
Does anyone no what years they put hydraulic roller tappets in instead of flat tappets. and also what is the difference between gt-40p and just gt-40 heads? which one will fit on my 91 gt. and how can i tell the difference? thanks guys
87 and up 5.0 engines have the roller cam setup in them. The GT40 and GT40P's will both fit on your engine but the P's require special headers or header sparkplugs like what accel makes. The P's flow better but have smaller valves that the regular gt40's. The GT40s will fit with no problems let you use any stock or aftermarket headers and net you decent gains in power.
I think '85 was the first appearance of the roller cam in the Mustang (or in any H.O. motor). Starting in about '87 or '88, most of the fuel injected 5.0's came with a roller cam - H.O. or not. The only exception is in the trucks as I've seen some '89's with the flat tappet cam in it.
The "P" heads require a special header - yours probably won't work. The spark plug comes out almost straight on these heads and the header tube will be in the way unless the tubes bend the other way or come straight out for a good 4 or five inches before they start to make the bend.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
