Lifter going bad???
already common 68 thousand miles thats bullsh*t...hmm exhaust manifold idk it might be that...as I said already I am so stupid when it comes to engine stuff so its prob going to cost me a lot of monies!
spray some pb oil arround the exhaust ports just after you start it up, if it blows out or bubbles you may have an exhaust leak .
If the manifold gets hot it may smoke away before you can tell anything.
most definately.
lol, he wont need to replace his valves if they are ticking.
The manifold 99% more than likely isnt leaking, the gasket between it and the head is probably busted at some spot.
i didnt say he had to replace them......i sed there not hard to adjust and a new set is not that expensive!
