Wheel Offset
Old 04-10-2003, 01:26 AM
gusbustamantejr
gusbustamantejr's Avatar
Default Wheel Offset
I just got some Eagle Alloy Cobra R knockoffs, polished. They are all 17x9. I mounted 255\40R17 all around. The fronts stick out about a 1/2 inch from the wheel wells, and the backs tuck in with room to spare. Should I just put spacers in the back to bring them out, or change the fronts? I like the tough look of a wider footprint.
Also, what kit should I use to lower the car about 1.5 inches?
Thanks
Gus
gusbustamantejr is offline
Old 04-11-2003, 01:10 AM
JUDE
JUDE's Avatar
Keep the front the way they are. Don't put spacers, just put some 275s in the back.
JUDE is offline
Old 04-11-2003, 02:08 AM
gusbustamantejr
Thought about that, but the wheels are visibly inside the fronts. Needs spacers AND 275's!
Old 04-11-2003, 03:16 PM
JUDE
JUDE's Avatar
How wide are the Corvette's rear?
JUDE is offline
Old 04-13-2003, 09:24 PM
Tangerine GT
Tangerine GT's Avatar
hey dude i have the exact same wheels. what center caps are you using? i wanted some different ones or possibly some stickers to put over the eagle stick any ideas where i could find them?
Tangerine GT is offline
Old 04-13-2003, 10:04 PM
gusbustamantejr
I have the Eagle Alloy cap on there. I may order some caps from MustangsUnlimited or some other catalog. Its not a big deal, but the offset is. What are you doing about the offset?
Old 04-17-2003, 11:18 PM
JUDE
JUDE's Avatar
Gus, the best way to fix the offset is to get another car.
JUDE is offline
Old 04-18-2003, 02:03 AM
gusbustamantejr
I used a universal spacer on the back which is about 3/8 inch, very small, but it helped.
Jude.....
MY OTHER CAR IS A VETTE
Old 05-16-2003, 03:07 PM
ianmgt50
ianmgt50's Avatar
I have a 94 gt with the same wheels and same wheels and 255\40s i hade the same problem and i got half inch wheel spacers it helped alot, they only cost about 15$ but my lug nuts are now holding about three threads, so any larger wheel spacers are around 150.00 because they have larger studs on them.
ianmgt50 is offline
Old 05-16-2003, 03:08 PM
ianmgt50
ianmgt50's Avatar
do you have alot of bump steer problems
ianmgt50 is offline
Quick Reply: Wheel Offset
