new mods now car wont run
Old 03-13-2009, 07:34 AM
Mike W
Mike W's Avatar
Originally Posted by ahittz24
Did you get the firing order right? remember this is a ford motor not a chevy so the cylinder count goes down the block
4 8
3 7
2 6
1 5
D
D marks Distributor
I bet you have a couple wires mixed up. This may help a little better. http://www.muscularmustangs.com/2005/firingorder.php
Mike W is offline
Old 03-13-2009, 09:26 AM
ahittz24
ahittz24's Avatar
I my diagram was intended to be an arial view of the engine, not of the distributor. I was marking cylinder location. D was marking the front of the engine where the distributor is.
ahittz24 is offline
Old 03-13-2009, 10:46 AM
WhiteWindsor
WhiteWindsor's Avatar
Originally Posted by AdderMk2
restab the disty... its probably in wrong
*cough*
Have you done this yet????????????
WhiteWindsor is offline
Old 03-13-2009, 02:31 PM
frost1357
frost1357's Avatar
Angry
lol out of g/p i checked the firing order.....it was right and stabed the distributor. still runs the same im startin to get mad.
frost1357 is offline
Old 03-13-2009, 02:57 PM
frost1357
frost1357's Avatar
Exclamation
hmmm i unplugged the MAF and it runs a bit better
Old 03-13-2009, 05:50 PM
Compression
Compression's Avatar
Are you getting a thick white smoke out of the tail pipes?
Compression is offline
Old 03-13-2009, 06:46 PM
frost1357
frost1357's Avatar
no theres no thick white smoke
Old 03-14-2009, 11:52 AM
frost1357
frost1357's Avatar
need some more help here guys
Old 03-14-2009, 03:42 PM
jthorn9
The Godfather
jthorn9's Avatar
Pull all of your spark plug wires out and look inside the sleeves and check the caps, I had a similar issue last week with mine after my build, turns out one of the caps was bent and wasn't making full contact with the spark plug, however mine caused the engine not to turn over what so ever.
As long as your MAF is the same size or larger as your TB this shouldn't cause an issue. Also, did you change the fuel injectors, if so, then that's your problem, MAF isn't calibrated to the fuel injectors, go pro-m.
If the above checks out, you'll need to run to autozone and get a tester. I can't thinks of it's exact name, but it looks like a screw driver and it lights up when a circuit is made. You'll need to pull out one of the plugs on your fuel injectors and test to make sure your injectors are getting an input signal. This will take two people, one to test, one to turn over the motor. If your injectors are getting a signal, the ground will stay lit, and the positive or input line should flash on/off rapidly.
If this checks out, then check your salt/pepper shakers at the back of your engine bay (a black/white sensor), to make sure they're not corroded, or damaged, the sensor may be able to check these as well.
If this checks out, do your fuel injectors have adequate fuel pressure?
jthorn9 is offline
Old 03-14-2009, 04:14 PM
OnyxCobra
OnyxCobra's Avatar
did you check your timing with a light? Stabbing the disty is EASY to mess up by just a tooth and it changes everything.
OnyxCobra is offline
Quick Reply: new mods now car wont run
