347 or 377?
Old 03-15-2009, 01:59 AM
cavemile
cavemile's Avatar
can anyone help , im building a 347, gt40p ported, 24lb or 30lb injects, havent chose valves yet either , exsploder intake,65mm throttle, cobra computer, for the street/strip. I need a cam? e? b? x? or comp nx274hr,? custom?
cavemile is offline
Old 03-15-2009, 06:56 AM
Portmaster
Portmaster's Avatar
There would be no sence in wasting the money on a custom ground cam on an engine that doesn't have the heads to support the cubic inches. If you absolutly have to use those heads I'd say a Comp XE270HR. Put a 3:55 in it max. Your engine will be suffering at 5000 rpm
Portmaster is offline
Old 03-15-2009, 07:51 AM
AdderMk2
Banned
AdderMk2's Avatar
Originally Posted by cavemile
can anyone help , im building a 347, gt40p ported, 24lb or 30lb injects, havent chose valves yet either , exploder intake,65mm throttle, cobra computer, for the street/strip. I need a cam? e? b? x? or comp nx274hr,? custom?
why build a great bottom end, to just top it off with a set of polished turds?
AdderMk2 is offline
Old 03-15-2009, 11:42 AM
duneking905
duneking905's Avatar
i was planning on buying a 351 block and start fresh. and keep my stock motor as a spare or maybe install it on my other ford truck.
duneking905 is offline
Old 03-15-2009, 11:54 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
cobra computer is calibrated for 24 lbs so 30 will not work with it. head choice sucks, so does intake and I'd go custom cam once you straighten out your top end.
mjr46 is offline
Old 03-15-2009, 12:13 PM
luckythirteen13
luckythirteen13's Avatar
dont even bother building the motor if those are the heads and intake your going to use
luckythirteen13 is offline
Old 03-15-2009, 12:14 PM
AdderMk2
Banned
AdderMk2's Avatar
care to explain why???
seems as though the 30# injectors work fine in my car..... food for thought
AdderMk2 is offline
Old 03-15-2009, 12:24 PM
mjr46
mjr46's Avatar
if you say they will I'd trust what you say more than since you are doing it
mjr46 is offline
Old 03-15-2009, 12:35 PM
OnyxCobra
OnyxCobra's Avatar
30lbers will work, just needs to be tuned for it.
OnyxCobra is offline
Old 03-15-2009, 12:40 PM
AdderMk2
Banned
AdderMk2's Avatar
you dont need a tune to run 30# injectors.... just need the right maf
AdderMk2 is offline
Quick Reply: 347 or 377?
