cam and piston help
Old 03-21-2009, 11:36 PM
fast stang15
fast stang15's Avatar
do u think this will be a streetable cam?
fast stang15 is offline
Old 03-21-2009, 11:49 PM
sastangman
sastangman's Avatar
u know that cam is a flat tappet non-roller.
do u have a roller 302 block or flat tappet?
sastangman is offline
Old 03-22-2009, 10:17 AM
fast stang15
can anyone tell me if the stock pistons had valve reliefs.
Old 03-22-2009, 12:00 PM
fast stang15
also i just took the cam out of a block i had. and the only letters i can fing are by the gear and they are ZEZE ZE and it looks like there is a f3 on the end of the cam but not sure. Can someone verify that this is a stock cam?
Old 03-22-2009, 12:09 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
before asking anymore questions, answer what has been posed....roller or non roller block are you using???
mjr46 is offline
Old 03-22-2009, 01:10 PM
fast stang15
ooops ya it is roller. its like a 1990 block
Old 03-22-2009, 03:39 PM
fast stang15
can anyone tell me if that is a stock cam, the one with ZEZE ZE
Old 03-22-2009, 06:19 PM
Portmaster
Portmaster's Avatar
That cam (in original post)is a solid flat tappet with over 250 degrees of duration @.050 lift the pistons have a .440 dome so that would put you around 11.5-1. Nothing you listed is very streetable unless you have a station selling 100+ octane fuel and you will have about a 300 rpm window of power. You would also need a new set of flat tappet lifters and a tough break in on that cam. You would have to break the cam in on one set of springs and then change to the running set. I'd back up and regroup
Portmaster is offline
Old 03-22-2009, 08:04 PM
fast stang15
ok well i was givin the cam so no biggy. lol
Old 03-22-2009, 08:11 PM
fast stang15
wat if i ran this cam with stock pistons?
Quick Reply: cam and piston help
