Headlights
Old 03-24-2009, 05:58 PM
blackrider
blackrider's Avatar
Default Headlights
My headlights went off only the highbeems works but only when you hold the them when you let them go they shut off how can I fix it
blackrider is offline
Old 03-24-2009, 06:02 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
may have a bad multi function switch.
mjr46 is offline
Old 03-26-2009, 11:46 AM
87foxgt
87foxgt's Avatar
pull the switch out for the lights and see if its melted in back. I had the same problem I guess this is common on stangs. I had to buy a new head light switch. make sure you label the wires so you know back where they go. also you may not have enough wire slack to just pull the switch out from the console so be prepared to rip it down to the cluster.
87foxgt is offline
Old 03-26-2009, 12:07 PM
USMC1775
USMC1775's Avatar
Check the bulbs as well to make sure the filaments are good
USMC1775 is offline
StalkerGT
11-28-2015 03:09 PM
Seanam
10-04-2015 10:15 AM
Drastang
09-29-2015 03:31 PM
Mobiusone stang
09-07-2015 08:46 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: Headlights
