Axle Housing Bushings
Old 04-05-2009, 11:46 AM
USMC1775
USMC1775's Avatar
Default Axle Housing Bushings
Without buying the $30 tool, whats my best way to replace those 2 bushings on top of the axle
USMC1775 is offline
Old 04-05-2009, 12:07 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
a torch to melt them out would work. or a big socket and a little socket and a big c clamp would get it started maybe
projectresto83 is offline
Old 04-05-2009, 12:10 PM
USMC1775
USMC1775's Avatar
Ok kind of like a balljoint press..
Do I need to lube the new ones to put them in? I got Prothanes
USMC1775 is offline
Old 04-05-2009, 12:49 PM
projectresto83
M.A.D. Motorsports
I would. It will make them alot easier to slide in. If you are worried about them comming out or moving around you can just spray wd40 on them instead. Do you still have the stock upper control arms on the phantim??
Old 04-05-2009, 01:08 PM
USMC1775
USMC1775's Avatar
No theyre tubulars but when I swapped them, the bushings looked good and I was naiive enough to go by that
USMC1775 is offline
Old 04-05-2009, 01:20 PM
projectresto83
M.A.D. Motorsports
What uppers and lowers do you have and how do you like them? I am gonna just buy a complete prothane bushing kit when i get home to start out the suspension. I would go with more but I have to put money else where. I figure its a nice way to upgrade the stock suspension on the 93 I just bought before I left to come to my 2nd vacation to the box. They will go well with the mm full length sfc.
Old 04-05-2009, 01:22 PM
projectresto83
M.A.D. Motorsports
What uppers and lowers do you have and how do you like them? I am gonna just buy a complete prothane bushing kit when i get home to start out the suspension on new fox. I would go with more but I have to put money else where. I figure its a nice way to upgrade the stock suspension on the 93 I just bought before I left to come to my 2nd vacation to the box. They will go well with the mm full length sfc.
Old 04-05-2009, 01:24 PM
USMC1775
USMC1775's Avatar
I got the BOI tubulars, Im pretty sure theyre the same exact thing youll get anywhere in a non-adj package. Im not too concerned about adjustability just yet, and when I get to that point, Ill be picking up some coilovers and a torque arm to replace the uppers anyway.
They come with good bushings in them and zirc fittings for greasability, just order the housing bushings at the same time, I got mine from stangsuspension.com <-- cheap and close to where I live
USMC1775 is offline
Old 04-05-2009, 08:11 PM
Modular_Madness96
Modular_Madness96's Avatar
That will work.
Yea put a little grease on them so they dont squeel.
Modular_Madness96 is offline
Old 04-06-2009, 03:27 AM
primetime5.0
primetime5.0's Avatar
if you jump onto MM's website they recommend NOT using poly bushings on the axle side..
primetime5.0 is offline
Quick Reply: Axle Housing Bushings
