Engine building 101...project semi-n00b
Old 04-28-2009, 08:59 PM
  #41
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
is your block a roller block or flat tappet one?? can't remember??
mjr46 is offline
Old 04-28-2009, 09:42 PM
  #42
Landcruisin60
Landcruisin60's Avatar
Its a flat tappet.
Landcruisin60 is offline
Old 04-28-2009, 09:47 PM
  #43
NotchAbove
NotchAbove's Avatar
Originally Posted by NotchAbove
Summit has a Sealed Power Kit for your motor for $520 w/ forged pistons. Get a 28oz balancer. You can pick up an Edelbrock top end kit from Summit for $1825, that will get you heads, lower intake, camshaft, gaskets and head bolts. Kit claims 367hp. Obviously when you build a car there are miscellaneous pieces you will need. But you could build this for about $3k.
Miss my post ? I think this is a decent build.
NotchAbove is offline
Old 04-28-2009, 10:40 PM
  #44
Landcruisin60
Nope I saw it when you posted and then forgot about it. It's probably going to be the direction I take. I assume that 367hp they claim will be at the crank. I got a quote to bore and hone my engine .030 over will be $225...is that reasonable? Should I also have my crank cleaned up and balanced? It looks to be in really good shape, all the bearings are in good condition.
Nick Oliver
10-17-2018 04:22 AM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Engine building 101...project semi-n00b
