Starter problem
Starter problem
When i try to start my car, it turns over but it sounds like the starter is still trying to start the engine while the engine is on. And when i turn the engine off it continues to try and turn the engine over. Even after i take the keys out. The only way i have been able to get it to go away is drive for awhile, but this gets quite annoying and im sure is bad for my engine and starter. Do i need a new starter?
sounds like your starter solenoid is bad. there cheap and easy to fix. you could try tapping it with a hammer or something to see if that fixes it but if its constantly grinding i wouldnt even drive it till its fixxed. thats going to chew your flywheel all to hell.
From what I have figured out no matter what selenoid you end up getting it will end up failing some time or later. It is a stupid design IMO.
ok so i had gone out and bought a new solenoid awhile back, it fixed it and now i went to start my car and it started doing the same thing and then it stopped, all i hear is spinning now . Is the starter bad and if so . How do i replace it and where is it located. I havent really looked yet since it just happened.
stangin1996gt
09-21-2015 11:01 AM
jaiidutch
09-14-2015 10:29 AM
