bolt size rear upper control arm
If one bolt is out of the control arm, take the other one out and match a bolt to that. The four upper control arm bolts are the same size. The four lower control arm bolts are the same size. However, the uppers are not the same size as the lowers.
You'll probably have a tough time finding a bolt like this in a hardware store, make sure its strong enough to handle the load. If i were you I would just get new bolts from Late Model Restoration or a similar company. Make sure you torque the bolts to provent this from happening again.
Its diffacult to find a 10.9 grade bolt especially at hardware stores or supply stores. Easiest place to find one is as said above, a restoration site. Now, being in Michigan you might have more luck finding metric bolts, and if not you might just hop across the border into Canada and find it.
NorthAmericanTuning
03-18-2016 11:21 AM
inyadreems
08-21-2015 09:10 AM
