head and cam lift
Old 04-28-2009, 10:09 PM
Lx88Notch
Lx88Notch's Avatar
Default head and cam lift
hey all, I'm looking at heads that have a .500 lift and was wondering if I can run a e303 cam with 1.7s (.520ish) or 1.6 (.498?) without hitting. I wasn't sure if the head lift coencides with cam, maybe a dumb question
Lx88Notch is offline
Old 04-28-2009, 10:43 PM
AdderMk2
Banned
AdderMk2's Avatar
heads dont have lift
AdderMk2 is offline
Old 04-28-2009, 10:49 PM
Lx88Notch
Lx88Notch's Avatar
Sorry, meant to say springs good to .500, does that mean it's a spring issue or valve issue and are they not usable
Old 04-28-2009, 10:51 PM
AdderMk2
Banned
AdderMk2's Avatar
always install springs that will match the cam. I honestly dont give a rats *** what comes with the heads... and max lift has NOTHING to do with PTV clearance
AdderMk2 is offline
Old 04-28-2009, 10:55 PM
Lx88Notch
Lx88Notch's Avatar
ok thanks, heads are fully rebuilt, ported the whole nine so I wouldn't have to change parts except springs
Old 04-28-2009, 11:00 PM
AdderMk2
Banned
AdderMk2's Avatar
um yea... you do.. dont argue with me
I dont give a rats *** if they say the springs are good for .600 lift and you run an F cam with .512... you ALWAYS match springs that are recommended FOR the cam!
AdderMk2 is offline
Old 04-28-2009, 11:06 PM
Lx88Notch
Lx88Notch's Avatar
Ok, thanks again, not arguing. Just a novice asking a question. Thank you for your answer.
Old 04-29-2009, 06:53 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
heads come with generic spring packages, while they will work for some cams, they need to be checked and compared to spring specs required by cam manufactorer.
mjr46 is offline
Old 04-29-2009, 03:23 PM
Lx88Notch
Lx88Notch's Avatar
Ok, new question the heads are D0OE, they have 1/2" head bolt holes, stainless steel valves 1.94" intake and 1.60" exhaust and the springs are 115# on the seat and 275# open, good to .500" lift, 58cc combustion chambers. The rocker stud bosses milled 3/16" with new screw in rocker arm studs and guide plates, new hardened exhaust seats. I know I need different pushrods and spacers for the manifold, and valve cover to do the 1.7s, but with an e303 will I have any ptv issues with this setup, it is a stock bottom end '92 302.
Old 04-29-2009, 03:36 PM
mustangmike33
mustangmike33's Avatar
well i think the ptv clearence wont be an issue. the springs however with this set-up is although. with a 1.7 rocker your looking at a 520, compared to a 1.6 at 498. you should either change those spring or leave the 1.6 on it. ive always been the kind of guy to say screw the springs, but never with a lift of the cam and the max lift of the spring having a big gap. so def. chang ethe springs or run the 1.6's until you change the springs.
mustangmike33 is offline
Quick Reply: head and cam lift
