Car stalls on start
Old 04-29-2009, 06:44 PM
89Mustangn00b
89Mustangn00b's Avatar
Default Car stalls on start
so when I start my car if I dont rev it for a little bit before I get going it stalls. After I drive about a mile or 2 and just sit in neutral everything is fine. It sounds like my fuel pump is dying when I first start it when I'm sitting there. My volt meter also bounces up and down when I hear my pumps dying sound. Not a battery issue b/c its brand new. I do have an E303 cam in it and not sure if that has nething to do with it or maybe I just need a new fuel pump. Let me know what you think.
89Mustangn00b is offline
Old 04-29-2009, 07:23 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
run a koer test and check for codes, if none look for vaccum leaks and or clean Iac motor
mjr46 is offline
Old 04-29-2009, 07:48 PM
89Mustangn00b
U think a vacuum leak? even though after a couple miles everything is fine?
Old 04-29-2009, 07:58 PM
84conversion50
84conversion50's Avatar
most definitely
84conversion50 is offline
Old 04-29-2009, 08:04 PM
89Mustangn00b
so loss of vacuum at the start will make the volt meter rise and fall and make the fuel pump sound like its dying?
Old 04-29-2009, 08:07 PM
84conversion50
all were asking you to do is check... while your under the hood check fuel pressure, vacuum lines, and get a voltmeter to test your alternator.
Old 04-29-2009, 08:08 PM
mjr46
mjr46's Avatar
if your car is about ready to die, you will see a drop in voltage, your focusing on the wrong thing, do as I stated
mjr46 is offline
Old 04-29-2009, 08:31 PM
89Mustangn00b
ok i'll take a look
djbigskrilla
09-20-2022 01:04 AM
msavoia23
12
07-07-2018 12:08 PM
fdnyems19
08-13-2015 09:36 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Car stalls on start
