Disappointing Dyno Numbers
Old 05-04-2009, 08:17 PM
89coupe
89coupe's Avatar
alright yea i know the bbk CAI isnt doing the trick. the guy at the dyno said i am getting too much turbulence through the mass flow sensor. thats why i want to go with the anderson powerpipe because the sensor is at the beginning of the pipe and is supposed to slow down the velocity of the air over the sensor. I would like to switch to 1 3/4 longtubes with an x pipe and powerflows. my flowmaster setup seems like its pretty restrictive. yea im torn on what size throttle body to switch to. i want the accufab racebody like grabbem suggested just don't want to go too large and end up hurting my performance
89coupe is offline
Old 05-04-2009, 08:20 PM
grabbem88
grabbem88's Avatar
you won't...hold up getting pics
grabbem88 is offline
Old 05-04-2009, 08:32 PM
grabbem88
grabbem88's Avatar
as you can see i had to take off quite a bit from the intake opening for just a 75 opening
Attached Thumbnails Disappointing Dyno Numbers-100_3786.jpg   Disappointing Dyno Numbers-100_4180.jpg
Old 05-04-2009, 08:36 PM
89coupe
89coupe's Avatar
alright. that shouldnt be too big of deal deal to do. that power pipe should help a ton too not to mention it looks sick.
89coupe is offline
Old 05-04-2009, 08:39 PM
turbosha
turbosha's Avatar
Originally Posted by grabbem88
bullshyt! my 75 racebody was great in the street..i lost nothing and i had 3.73's
btw an 80mm wont work..
89 coupe you took my statement wrong..when rumors and opinions fly you tend to look at what you have that fits in that area...i won't change my mind about afr,but i will say this..take the bbk cai mass air metter off and get an accufab racebody bigger headers
and yes a custom cam...mine sit's in a closet
calm down skippy.i have a 75mm trick flow and 3.73's to.i didnt say a 75 wouldnt work. i said be carful on how big you go. you wouldnt put a 1050 dominator on a 289 would you? well maybe you would !
turbosha is offline
Old 05-04-2009, 08:41 PM
grabbem88
grabbem88's Avatar
you should see it now...it's a ghost town now
it's not that big a deal,but remember the fender needs to be cut for a 4 inch whole,and your meter will be in the fenderwell now...
Old 05-04-2009, 08:44 PM
grabbem88
grabbem88's Avatar
have you put a 90mm on your ride?
and t-body and a carb are totally different animals
Old 05-04-2009, 08:48 PM
89coupe
89coupe's Avatar
yea that won't be a big deal either. hopefully those changes will help. i probably wont do the cam until the end of the summer. i only have about 400 miles on the new motor anyway so ill have to live with it for a little while
89coupe is offline
Old 05-04-2009, 09:11 PM
grabbem88
grabbem88's Avatar
here' the hole
Old 05-04-2009, 09:49 PM
89coupe
89coupe's Avatar
alright sweet thanks for your help grabbem
89coupe is offline
Quick Reply: Disappointing Dyno Numbers
