Need Advice
Old 05-10-2009, 09:24 PM
calomino
calomino's Avatar
Default Need Advice
Does anyone know if the fenders and doors from a 93 GT will fit on an 89 GT? I just repainted my stang and there is a bigger than normal gap between the hood & fenders/ doors & fenders and a small gap between the top frame of the door and the pillar(small enough that you can see light through it) Any way to adjust these parts? All weatherstripping is brand new on the doors.
calomino is offline
Old 05-10-2009, 09:36 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
are the door bushings worn out??
mjr46 is offline
Old 05-11-2009, 04:52 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Yes they are interchangable. You just need to do some adjustments on your body panels.
projectresto83 is offline
Old 05-11-2009, 08:42 PM
calomino
calomino's Avatar
were are the door bushings located? thanx
calomino is offline
Old 05-12-2009, 01:23 AM
projectresto83
M.A.D. Motorsports
On the door hinges... If you open the door there is a pin that goes thru each hinge and there are 2 bushings on each hinge, top and bottom.
http://www.latemodelrestoration.com/...0%201&comp=LRS
Omgitsa88Stang
10-05-2015 07:33 AM
Shadow7874
09-24-2015 09:06 PM
2k232
09-16-2015 10:28 AM
EASTIDEE123
09-15-2015 11:08 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Need Advice
