wheel hop! need input
Old 05-13-2009, 06:04 PM
Jaked4e
Jaked4e's Avatar
Default wheel hop! need input
I have a 88 Gt that has aprx. 340 horse and i have a terrible wheel hop problem any time i give the car enough gas to spin the tires when going a low speed or when going around corners quickly.
I changed out the struts and shocks (which were still origanal) with KYB GR2 but that did not help at all.
The tires i have a basicly bald but i have not heard that much about that being a problem with wheel hop.
any suggestions on the culprit?
Jaked4e is offline
Old 05-13-2009, 07:25 PM
Portmaster
Portmaster's Avatar
What control arms do you have in the rear?
Portmaster is offline
Old 05-13-2009, 07:40 PM
Jaked4e
Jaked4e's Avatar
they are stock so they have 125k miles on them
Jaked4e is offline
Old 05-13-2009, 08:01 PM
grnstang
grnstang's Avatar
get new control arms. do you still have quad shocks in place?
grnstang is offline
Old 05-13-2009, 08:10 PM
Jaked4e
Jaked4e's Avatar
those are a specific type of shock correct? like are they a type of shock absorber that runs up and down or something else. Either way i think its a no i just put KYB GR2 shocks on yesterday. upper and lower control arms?
Jaked4e is offline
Old 05-13-2009, 08:11 PM
grnstang
grnstang's Avatar
the quad shock is inside the rear tires
grnstang is offline
Old 05-13-2009, 08:24 PM
Jaked4e
Jaked4e's Avatar
thats a no then the suspension is compleatly stock untill yesterday with struts and shocks
Jaked4e is offline
Old 05-13-2009, 08:30 PM
grnstang
grnstang's Avatar
that is part of the stock suspension. are you sure? that would cause wheel hop if they arent there. you need to buy aftermarket rear upper/lower control arms with polyurethane bushings and that would keep your axle planted
grnstang is offline
Old 05-13-2009, 08:43 PM
Jaked4e
Jaked4e's Avatar
o in that case then they probally still there. any idea if tires play into the picture because mine are fairly wide 255's and could be considered slicks how bald they are
Jaked4e is offline
Old 05-13-2009, 10:22 PM
grnstang
grnstang's Avatar
that MIGHT be the reason...i remember when my drag radials were really bald my car was spinning in every gear...but i didnt get any wheel hop. im kinda stumped. get some control arms
grnstang is offline
Quick Reply: wheel hop! need input
