edel performer rpm heads
The Trickflow is a decent setup, but you might be more satisfied with a more solid setup. I agree with the Steeda #18 cam for you, it will fit well with in the powerband of your basic Eddelbrock and Trickflow intakes and heads. Crane, also a great choice, but very hard to find now, I had to wait nearly 6 months for my 1.7 roller rockers, but at least I got them before they became nearly unavailible.
the trickflow setup will get a T5/3.73 SN95 to a 12.99 for sure. a friend did that after launching on bias ply et streets @ 5k. full weight car. the auto was much slower, same weight sn95, not sure on the gear.
being i owned a set of rpm heads, they are alright, i have seen some decent dyno #'s, not that numbers mean alot, the cam will play a big part on how fast the car is going to accelerate. the main problem with those heads is the problem i had, spring pressure was way to weak. if you can get them for say $600-700 and happy with a high 12, low 13 ET, then have the springs changed to match the cam and have the valve seats checked. i ran mine for ~700 miles and sold them for $850.
I'd actually go even lower, cause the thing is , they belong to a friend and I have them at work so I'd like to sell them as the freind owes me a healthy sum for getting his 1100 yamaha virago running that had been sitting for 5 years.
Omgitsa88Stang
10-05-2015 07:33 AM
panic
09-10-2015 05:56 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
zanemoseley
09-06-2015 12:58 PM
