thinking of supercharging
Old 05-18-2009, 07:26 PM
ctlazersplaya07
ctlazersplaya07's Avatar
Default thinking of supercharging
so i am thinking of supercharging my car. i know it is a project that is for those who are mechanically strong, so i got a buddy who is extremely good with cars and works in a garage to help me with it, but i was wondering if there were any certain modifications i would have to make before buying the supercharger, installing it, and if their were any kits that came with all the necessities to make it work correctly with my engine, including gaskets and hoses etc.....any information would be greatly appreciated
ctlazersplaya07 is offline
Old 05-18-2009, 09:08 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
depends on what level of boost you wanna run?? with upper levels of boost , fuel system mods start to become a necessity.
mjr46 is offline
Old 05-19-2009, 09:20 AM
ctlazersplaya07
if i ran like 8 psi...what should i modify to accompany that
Old 05-19-2009, 04:31 PM
bpark8824
bpark8824's Avatar
With lower boost like that I don't think you would need to do much.
Anyone know how much a 5.0 makes on about 8psi? I was thinking about s/c'ing mine next winter...
bpark8824 is offline
Old 05-19-2009, 07:42 PM
mjr46
mjr46's Avatar
normally the stock kits run 5-6 psi on the stock fuel system, 8 would be pushing the stock inj duty cycle to the max
mjr46 is offline
Old 05-20-2009, 12:00 AM
92hatchLX
92hatchLX's Avatar
Even with 6 lbs I'm running some high-performance FRPP 36 lb injectors (picked them up new for 100 bucks, can't beat it!), recal'd 75mm Pro-M bullet MAF with the supercharger and conical filter calibration, an FMU, timing at 8 degrees, Walbro 255lph. Just to be on the safe side. If you've got money to blow after the supercharger get it professionally dyno tuned. If not, just play it safe on the timing, boost and fuel. You'll for SURE feel a difference with 6psi. It's amazing when you feel the motor starting to build boost the tone of the exhaust changes and how it starts pulling you into your seat is a great feeling.
92hatchLX is offline
Old 05-20-2009, 06:00 PM
bpark8824
bpark8824's Avatar
About how much would it make on 6 psi? is 350 a realistic goal?
Old 05-20-2009, 07:56 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
IMO not without at least better than stock heads (and springs) and intake.
JD1969 is offline
Old 05-21-2009, 11:33 AM
19905.0stang
19905.0stang's Avatar
vortech sells a s trim kit that runs 8 to 10 pounds of boost
19905.0stang is offline
Old 05-21-2009, 01:02 PM
TdS!
TdS!'s Avatar
Anyone in here run the 302 or BOSS 302 with more boost... Say in the 15 - 20psi range?
I'm buying a new BOSS 302, and want to boost the hell out of it... But hadn't made up my mind about a s/c or a t/c... I know I'm gonna have to replace the headers, pistons, cam, put in a cooling system and and better fuel system, and much better intake... but any reccomendations, or usefull info as far as pros and cons for s/c over t/c?
TdS! is offline
Quick Reply: thinking of supercharging
