1986 5.0L,
Old 05-24-2009, 08:49 PM
86GT5.0LHO
86GT5.0LHO's Avatar
Exclamation 1986 5.0L,
Hello, I have a 86 EFI 5.0L. AOD. just tore down. Im wanting to keep the crank, but go with forged rods, and pistons. with a E303/F303 Cam. scrap the stock heads, and go with GT40x Aluminum. with performance hydraulic rollers. and a trick flow upper and lower I.M. with a 70mm TB. with speed density. also putting.long tubes, with no cat. x pipe, to FM with turn downs
but I dont want to mess with MA, or the harness/computer. then run a A/C eliminator, and scrap all the smog.
shorter serp. belt.? any help. suggestions? will this setup work. Thanks.
86GT5.0LHO is offline
Old 05-24-2009, 09:05 PM
NotchAbove
NotchAbove's Avatar
From what I have read, and through experience, you will not be able to run a different cam with the speed density. Plus with the items you stated, you would be better served with 24# injectors, which will not work either.
With that said, I believe you need to go Mass Air or Carb.
NotchAbove is offline
Old 05-24-2009, 09:19 PM
86 5.0L
86 5.0L's Avatar
you can do anything on a SD car as you would a MAF car, you just have to be more selective on the cam, I have a sticky with a chart explaining which cams/specs are SD compatible
86 5.0L is offline
Old 05-24-2009, 09:24 PM
AdderMk2
Banned
AdderMk2's Avatar
sounds like you want to go carbed
AdderMk2 is offline
Old 05-24-2009, 09:40 PM
NotchAbove
NotchAbove's Avatar
I was unaware, but there has to be a limit ? I'm sure 42# injectors will not work or ??
Old 05-24-2009, 09:54 PM
AdderMk2
Banned
AdderMk2's Avatar
you cant realistically swap injectors on a SD system. Unless you are a mathematical genious, and can get your setup to require the exact amount of fuel a larger injector will put out
im still not sure that the tweecer or Moates QH can tune an SD ecm
AdderMk2 is offline
Old 05-25-2009, 07:09 PM
86GT5.0LHO
86GT5.0LHO's Avatar
can I see it.
Old 05-25-2009, 07:10 PM
86GT5.0LHO
86GT5.0LHO's Avatar
so what do you recommend?
Old 05-25-2009, 07:35 PM
NotchAbove
NotchAbove's Avatar
You should check out the Speed Density Forum, there is a guy there with a 347, however he is running a very mild cam and 24# injectors. Check it out.
Jack Weinmann
09-25-2015 03:59 PM
09-17-2015 07:32 PM
jaiidutch
09-14-2015 10:29 AM
dalefrancis88
09-11-2015 07:15 AM
09-10-2015 08:39 PM
Quick Reply: 1986 5.0L,
