deciding headers and mid pipe
#23
haha the funny thing is ford tough is that my parents are actually moving to VA this summer, so if i were to register my car over there it seems that i wouldn't need the smog test according to what you said. not sure how long tubes would be hard to install. i have a lift and everything i can use to get under my car so that part wouldn't be hard. just curious why you guys would say to do unequal shorties if i did shorts, isn't equal better because it evens out the exhaust pressure and would give equal performance for each cylinder?
depends what county i guess you're in
#24
huh, interesting. your probably right, it most likely does depend on the county. i know that in WA where i am now, i need smog test, but if i registered over in the small area of Walla Walla i wouldn't need it
#27
Hey sitruk, I'm in Washington also and looking to get at least a new midpipe.
If I end up getting a pipe, i'd be going with a BBK catted h-pipe, since I can't really find any other brands of catted h-pipes (including MAC). However, I think the BBK pipe does sound very good.
But, if you're going for longtubes and a shorty midpipe, you might want to search youtube for some 5.0 exhaust videos with a similar setup. Try things like "longtube 5.0 mustang" or "bbk LT mustang" etc. Also, a good place to check for sound clips is http://www.mustangexhaust.com.
By the way, is it possible to install cats on an o/r h-pipe? Like do they have splits in the pipe for installing them? Because some o/r h-pipes are really cheap, so buying cats for them might be cheaper than buying an h-pipe with cats.
#28
Just get the one with cats
#29
sitruk,
Where abouts are you?
I'm in Arlington... no emissions tesing.
Move to Marysville (stones through), and there is testing.
I would go with long tubes. Main reason being to support future changes better.... and I think I would even go with 3"... but that will get some arguments from others here
As far as X or H... dunno... There are a ton of variables that would make one better than the other, and I know enough to know I'm not smart enough to predict that with any accuracy
Drop me a pm guys... I'm always looking to meet more local yocal Washingtonians
jason
#30
By the time you have a shop weld them together for you, I doubt you would see a cost savings. If you can weld it yourself, then you may be onto something....
sitruk,
jason
sitruk,
jason
