tko guys inside
Old 05-26-2009, 08:02 PM
ctgreddy
ctgreddy's Avatar
Default tko guys inside
what do these plug into/do?
and i'm guessing the speedo goes in here...
now where can I get the part to put in there, I tried the one out of my aode, and obviously it didn't fit lol.
also where can I get a rear seal for a 3550?
ctgreddy is offline
Old 05-26-2009, 08:09 PM
67mustang302
67mustang302's Avatar
There's a connection for an electrical speedo(as well as the mechanical hookup) and also a neutral safety switch and a reverse light switch.
67mustang302 is offline
Old 05-26-2009, 08:16 PM
ctgreddy
ctgreddy's Avatar
i figured thats what they were, but which ones are which?
ctgreddy is offline
Old 05-26-2009, 08:59 PM
67mustang302
The pigtail at the rear of the trans on the driver's side is neutral safety, the 2 prong dealy on the side of the case on the driver's side is reverse light, the hole with the gear is mechanical speedo(duh) and on the passenger side is a deal sticking out(kinda L shaped) for electronic speedo pickup.
Old 05-26-2009, 09:02 PM
redpony88
redpony88's Avatar
wow..... they're the SAME connections as the t-5.... seriously?
67's correct
redpony88 is offline
Old 05-26-2009, 09:14 PM
ctgreddy
ctgreddy's Avatar
67's correct
so if I order a speedo pickup for a t5 it'll fit then?
thanks for all the help fella's.
ctgreddy is offline
Old 05-26-2009, 10:01 PM
primetime5.0
primetime5.0's Avatar
although not very helpful, the wiring for my tko was the same as the t-5.. FYI if it has the stock shifter replace it with an MGW
primetime5.0 is offline
Old 05-26-2009, 10:31 PM
67mustang302
I stuck a Tri Ax on mine
The stock wasn't that bad....until it rattled apart
Old 05-27-2009, 05:25 AM
ctgreddy
ctgreddy's Avatar
i already got the mgw. i heard the shifter sucked.
ctgreddy is offline
Old 05-27-2009, 09:00 AM
Jfsram
Jfsram's Avatar
Just to clarify the neutral switch is for the computer. Not to keep the saftey switch to keep the car from starting.
Jfsram is offline
Quick Reply: tko guys inside
