5.0 wont rev past 5500
Old 06-06-2009, 12:34 PM
mikekx65
mikekx65's Avatar
Default 5.0 wont rev past 5500
I have a 88 GT with a mild 302. The problem is that the motor cuts out around 5500 it runs and drives fine up until about 5500 then it starts to cut out. Any ideas?
mikekx65 is offline
Old 06-06-2009, 12:42 PM
mattdel
mattdel's Avatar
The cars computer has a built in fuel cutoff around that area... I don't remember the exact number but you don't need to be any higher than 5500 anyway. You're not making any power.
mattdel is offline
Old 06-06-2009, 01:00 PM
mikekx65
mikekx65's Avatar
I'm running a N-412 cam and the specs say it makes power up until 6200....i dont see why it wouldnt make any power past 5500....
mikekx65 is offline
Old 06-06-2009, 01:37 PM
primetime5.0
primetime5.0's Avatar
cutoff is 6250, do you have the correct valvetrain to match the cam specs?
primetime5.0 is offline
Old 06-06-2009, 02:20 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
what springs you running on the heads??
mjr46 is offline
Old 04-05-2012, 08:42 AM
superduck352
superduck352's Avatar
i have the same problem dont ackt nuthing like a rev limiter its a bitch in a race
superduck352 is offline
Old 04-05-2012, 05:37 PM
nitrous_bob
nitrous_bob's Avatar
what kind of plug do you have ?
close them up to .046" and see how it runs
are they copper plugs ? or crappy platinum or iridium ? if either....dump them
nitrous_bob is offline
Old 04-07-2012, 07:27 AM
capri debris
capri debris's Avatar
Sounds like a big cam and weak valve springs.... resulting in valve float at anything above 5500 RPM.
capri debris is offline
Old 04-10-2012, 09:03 AM
Em_DynamicTurbo
Em_DynamicTurbo's Avatar
Same thing happened to mine. I got a diablo Sport chip (extender) and now i can go to almost 7000rpm's
Em_DynamicTurbo is offline
Old 04-10-2012, 11:42 AM
im_stuck_in_iraq
im_stuck_in_iraq's Avatar
Smile
what plugs you recommend?
im_stuck_in_iraq is offline
Quick Reply: 5.0 wont rev past 5500
