Herky jerky
Old 06-20-2009, 06:56 AM
steve58
steve58's Avatar
Default Herky jerky
neck snapping sticky accelerator. My gas pedal seems notchy when going slow in 1st and 2nd gear, through like parking lots, traffic back ups etc.
The cable is not visible to the human eye ,as its buried between the dash and back of the motr.
Looking to lube it somewhere,, any secret spots that causes this problem?
steve58 is offline
Old 06-20-2009, 09:20 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
grab the throttle body and roll the linkage slowly and see if it's smooth, if it is then the prob is most likely the cable, no way to lube it, it most likely is unravling inside, better replace it before your throttle gets hung up at WOT
mjr46 is offline
Old 06-20-2009, 09:21 AM
mjr46
mjr46's Avatar
mjr46 is offline
Old 06-20-2009, 09:42 AM
steve58
steve58's Avatar
Replacing the cable looks like a major process! Especially since my service manual hasnt showed up yet,,Any tips to make it easier?
steve58 is offline
Old 06-20-2009, 11:32 AM
tohoopty
tohoopty's Avatar
there are 2 screws on the fire wall that you take off.then it pops off the firewall and at the gas pedal
tohoopty is offline
Old 06-21-2009, 01:09 AM
Jfsram
Jfsram's Avatar
The throttle blade maybe jamming in the bore.
Clean the inside with combustion chamber cleaner or throttle body spray.
If that doesn't help. Check the stop screw for the throttle blade. It may be worn down or peened over. Turn it in a bit.
Jfsram is offline
Old 06-21-2009, 07:37 AM
steve58
steve58's Avatar
You know I must say,,,, being a lifelong Chevy guy and this Mustang being my 1st Ford,,, I know very little about them.
I've been waiting for my Service Manual for about a month,, They say its coming. So until I get it I'm skeptical of taking stuff apart that I have no experience with.
Any place I can get some detailed directions on cleaning the Throttle Body?
The linkage itself seems stiff,, The cable seems smooth with tension off it,the return spring is definitely doing its job! The car sat for about 3 yrs. and I just tagged it about 2 months ago,,, so I'm still working out the bugs,,This is an annoying problem.
steve58 is offline
Old 06-21-2009, 12:04 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Get some throttle body cleaner and spray it inside the throttle body and work the throttle back and forth.
projectresto83 is offline
Old 06-21-2009, 06:30 PM
steve58
steve58's Avatar
Not quite sure how to access the TB
steve58 is offline
Old 06-21-2009, 07:07 PM
AdderMk2
Banned
AdderMk2's Avatar
follow that big black tube from the air filter, until you get to the big metal thing on top of the engine... unscrew the clamp on the end and pull the tube off.
Guess what the metal thing you are looking at is....
AdderMk2 is offline
Quick Reply: Herky jerky
