SuperCharger
Old 06-29-2009, 07:08 AM
jjp278
jjp278's Avatar
Default SuperCharger
I have a 95' 5.0 with very little done to it. I was looking to SuperCharge it and would like some guidance. Is it wise to do the suspension work first and if so about how much would this cost? Do I need any modifications done to the engine before doing so?
Thanks for the help.
I have an intake, chip, new clutch, ignition system, flow master x pipe
jjp278 is offline
Old 06-29-2009, 09:41 AM
TrimDrip
FudgeDrip
TrimDrip's Avatar
if you are going with one of these centi blowers, you probably won't need suspension for the track.
Then again, I forget how much different my car handles from hardtop cars. You may want to invest in some traction bars and see how it does.
If I had it to do all over again, I would have put my money in a top end kit first.
TrimDrip is offline
Old 06-29-2009, 01:12 PM
ibayter
ibayter's Avatar
I just learned from my friend, He start doing the top end first with supercharge and a 13 Lbs of boost pulley and He has 520 H.P and now he wants some more horses but He did not do the bottom end, so it depends what you want, I think planning first what you want to do and then hoping you will not change your mind and go from there. but if I would do mine I will start from the bottom end first.
IBM
ibayter is offline
Old 06-29-2009, 10:50 PM
sick89
sick89's Avatar
I had a bone stock 91 5.0 with a kenne bell supercharger on it and it was a blast. I ran 6lbs of boost and the motor held together good. As long as your stock suspension is in good shape its not a necessity to upgrade. If you want to run a higher boost then think about building the motor otherwise 6-8lbs of boost was fun.
sick89 is offline
Old 06-30-2009, 09:13 AM
Black SunShine04
Black SunShine04's Avatar
Did you see this on ebay?
http://cgi.ebay.com/ebaymotors/1994-...lenotsupported
Black SunShine04 is offline
Old 06-30-2009, 09:29 AM
S-Trimmed302
S-Trimmed302's Avatar
A Supercharger was by far the Best Mod I ever done when my car was pretty close to Stock!Next best things were Gears and Maximum Motorsports Frame Connectors!
S-Trimmed302 is offline
Old 06-30-2009, 10:39 AM
smacked1
smacked1's Avatar
which supercharger do you have/part # and how many lbs of boost do you run? how much did it cost installed or did you install it
this is my next step for some good horsepower
smacked1 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
col2560
09-25-2015 08:59 PM
Quick Reply: SuperCharger
