poor idle
Old 11-13-2003, 06:17 PM
94BLKCOBRA
94BLKCOBRA's Avatar
Default poor idle
i have a 94 cobra that idles very poorly, it seems like the local mechanics cant get it right. i had the computer scanned and it came up with no codes, but it displayed throttle position sensor out of adjustment. so i replaced it and still a poor idle any where from 1000rpm's to 400rpm's. all gaskets from the cylinder head up are new and the are no cracked vacuum hoses. there is no check engine light on. does anyone have a answer? thanks.
94BLKCOBRA is offline
Old 11-13-2003, 07:29 PM
89muscle
89muscle's Avatar
Default poor idle
grounds, grounds, grounds. maybe coil and ignition.
89muscle is offline
Old 11-15-2003, 12:03 PM
94BLKCOBRA
94BLKCOBRA's Avatar
Default poor idle
do you think grounds could cause stalling as well? it stalls when i stop or turn the wheel hard at a stop. also if let of the gas at low driving speeds you can feel the car jerking.
Old 11-15-2003, 04:27 PM
Pitviper100
Pitviper100's Avatar
Default poor idle
could be the fuel filter
Pitviper100 is offline
Old 11-15-2003, 05:44 PM
94BLKCOBRA
94BLKCOBRA's Avatar
Default poor idle
nah, i already replaced the fuel filter.
Old 11-15-2003, 08:40 PM
89muscle
89muscle's Avatar
Default poor idle
did you try your ignition module?
89muscle is offline
Old 11-16-2003, 04:28 PM
94BLKCOBRA
94BLKCOBRA's Avatar
Default poor idle
i think i'll check that igniton module, thanks!
Old 11-17-2003, 11:46 AM
94BLKCOBRA
94BLKCOBRA's Avatar
Default poor idle
Checked the ignition module and coil yesterday at autozone ,they both checked out to be good, aslo i checked the egr with a vacuum pump and that was holding vacuum, i think i'm runnin out of ideas, could use some more help.
Old 11-17-2003, 12:59 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
Default poor idle
Fuel, Ignition, or Compression</P>
The basis of all diagnosis</P>
Fuel: check to ensure you have the proper fuel pressure and mixture</P>
Ignition: solid strong spark at the right time</P>
Compression: Cylinder pressure, cranking and holding. Biggest factor are things like head gasket, valve seating, rings, and cam timing.</P>
Take the car to a different mechanic. Diagnosing problems and swapping parts require totally different abilities, most "mechanics" can only swap parts.</P>
mdvaldosta is offline
Old 11-17-2003, 03:47 PM
94BLKCOBRA
94BLKCOBRA's Avatar
Default poor idle
Thanks i think i'll go from here, and see what i get.
Quick Reply: poor idle
