Power Loss and Smoke
Old 07-20-2009, 11:04 PM
cholericfc
cholericfc's Avatar
Default Power Loss and Smoke
So my car is smoking and lagging. I ran over a trash can lid and drug it around with my exhaust for a mile on some back-road recently. I thought maybe it was the plastic burning off. Its something else. But everything is brand new (mechanically) on this car. My friend said get rid of my chrome thermostat housing because the tend to leak. I've had real small leak for a while, but the car never smoked. My T5 has been leaking a little ATF here and there, but its been doing it for a while and never smoked.
I recently was underneath the car, and I noticed the one tranny-mount nut was missing and the other was loose - I got new bolts. I also found out the holes were stripped on the tailshaft housing. So I bought longer bolts and nuts to make everything nice and snug. Ever since then my car has been sputtering or making the same noise the car makes when it runs out of gas.
Is my clutch going? universal joints? engine problems?
thanks in advance guys.
cholericfc is offline
Old 07-20-2009, 11:46 PM
cholericfc
cholericfc's Avatar
also, I just reset the idle and runs/idles perfect right were I want it.
Old 07-20-2009, 11:50 PM
NoGo95GT
NoGo95GT's Avatar
So, did you fix it?
NoGo95GT is offline
Old 07-21-2009, 09:40 AM
cholericfc
cholericfc's Avatar
when I fixed the tranny mount, its been doing this ever since.
Old 07-21-2009, 10:53 AM
Tony71502
Tony71502's Avatar
Smoke from exhaust = engine burning coolant or oil internally
Smoke from engine bay = oil or coolant leak that's getting burned off probably on headers
Smoke from anywhere else = burning clutch/tires/brakes
Basically
Tony71502 is offline
Old 07-21-2009, 01:28 PM
cholericfc
cholericfc's Avatar
I just installed an oil pressure gauge and it was leaking on the gauge-side... all over the inside of the car, tightened it up... not sure if the car will still smoke or not. I have a feeling the oil was falling out of the shifter hole down the side of the tranny and exhaust.
FYI - I meant it was smoking from underneath the car - exhaust and tranny
baddog671
07-26-2016 01:20 PM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
RCS02v6
09-29-2015 01:46 PM
MacSerio
09-27-2015 01:05 PM
Quick Reply: Power Loss and Smoke
