runs like crap after cobra intake install
Old 08-03-2009, 08:28 PM
loeryder21
loeryder21's Avatar
Default runs like crap after cobra intake install
i helped my friend install a cobra upper and lower set on an 86 gt and its running horrible. Would it be possible that the vaccuum lines are wrong which is causing this? we never got a diagram or anything so we werent sure which lines went where, just kinda did it randomly. I cant find too much online so i figured i would give you experts a shout out
Thanks
loeryder21 is offline
Old 08-03-2009, 08:33 PM
a_penquin
a_penquin's Avatar
quite possibly a mixed vacuum line, maybe a vacuum leak could be a culprit. would get a diagram for the line locations first then work from there
a_penquin is offline
Old 08-03-2009, 08:40 PM
nacanitihs
nacanitihs's Avatar
hose it down with some carb cleaner to see if there is a leak. if so the rpm will rise. its also kinda hard to mess up the vac lines as they all go to basically the same point.. and there is only like 3 that you touch doing an intake
nacanitihs is offline
Old 08-03-2009, 08:41 PM
loeryder21
loeryder21's Avatar
any idea where i could get one? i think it might be on the tree under the intake where i messed up but im not sure, is there a site or anything?
Old 08-03-2009, 08:46 PM
AdderMk2
Banned
AdderMk2's Avatar
make sure you dont have a vac line directly to the EGR
AdderMk2 is offline
Old 08-03-2009, 08:48 PM
nacanitihs
nacanitihs's Avatar
http://www.veryuseful.com/mustang/te...g5.0Vacuum.gif
i know it says 88 but it would be the same
here is the rest of the links in case you need any more
http://www.veryuseful.com/mustang/tech/engine/#Diagrams
are you sure you installed the lower correctly? did you use the noodle or cork?
Old 08-03-2009, 08:51 PM
loeryder21
loeryder21's Avatar
thanks for the diagram, what do you mean noodle or cork? im pretty sure i installed it right... didnt seem too complicated.
Old 08-03-2009, 09:09 PM
nacanitihs
nacanitihs's Avatar
on the lower. the front and rear part of the gaskets. was it blue and rubbery or was it made of cork? did you use a little rtv on the corners or a lot? too much can cause a leak and so can too little.. u need just the right amount. but spray the intake where the gaskets are w/ carb cleaner to see if the rpm rises like i said earlier
also if you dont place the lower just right the gaskets can move and thats no good either..
did you torque them in the right sequence? and to correct spec?
Old 08-03-2009, 09:10 PM
AdderMk2
Banned
AdderMk2's Avatar
actually, its good practice to NOT use the end pieces at all.. RTV FTW. thats all I use to seal my lifter valleys
AdderMk2 is offline
Old 08-03-2009, 09:35 PM
Sidewayz6.0
Super Moderator
Sidewayz6.0's Avatar
^^^ What he said. Throw those rail gaskets away. Just use about a 1/4 inch bead of RTV Ultra Black.
Sidewayz6.0 is offline
Quick Reply: runs like crap after cobra intake install
