msd
Old 11-15-2003, 01:23 AM
af41
af41's Avatar
Default msd
is msd ignition a waste of money on a slightly modified 5.0? I always heard that msd only should be used if your 5.0 was blown or was pushing well over 300 ponies. Will msd ignition do anything for a 5.0 with mostly bolt-ons? I have a 94 cobra with superchip, 3.73s, msd coil, x pipe, maf, and k&n kit. Will the msd really do much for my mods?
af41 is offline
Old 11-15-2003, 03:02 AM
makarovboy
makarovboy's Avatar
Default msd
Although ford has a good ignition, I went with the crane hi-6s box and was impressed. With my aod, the idle was a little lumpy, be sitting at a light and it would drop down, then pick back up, nothing drastic but irritating. The crane box smoothed it out, plus I have the rev limiter and can add a timing retard box if I go with s/c or nitrous. I don't think you could go wrong by getting an upgraded ignition, and they have become fairly inexpensive.
makarovboy is offline
Old 11-15-2003, 05:16 AM
t3000
t3000's Avatar
Default msd
Dude believe it or not, I have one on my Civic. It did wonders for my throttle reponse. I don't know how much it'll change for a 5.0, but that is one of the first mods I'm getting for my stang.
t3000 is offline
Old 11-15-2003, 01:25 PM
vfast
I ♥ Acer
vfast's Avatar
Default msd
they are great ...I would however put in a nice msd distrutor and the 6al box and some very low ohm rest. plug wire. you will see a difference and will start easier/quicker
vfast is offline
Old 11-15-2003, 08:42 PM
89muscle
89muscle's Avatar
Default msd
the stock distributor works good tho, if you put the msd 6al box in it you should get like 5-10 hp, not enough to feel the difference but when the other bolt on parts start adding on, then you will be glad you have it.
89muscle is offline
firehorse02
11-16-2015 11:28 AM
mirandaandjimmy
11-16-2015 08:51 AM
JonnyBlazeGT
11-03-2015 01:10 AM
T5superduty
01-15-2004 08:16 PM
cjoracing
01-06-2004 03:17 AM
Quick Reply: msd
