Power loss, hesitatation, sputter, chug
Old 01-21-2010, 12:19 PM
  #101
cholericfc
cholericfc's Avatar
So, I can't get it to be any lower than that - Something else must not be right..
I'll post this weekend.
cholericfc is offline
Old 01-21-2010, 01:04 PM
  #102
89stangbanga
89stangbanga's Avatar
That code reader you bought works for all year foxes right with the EEC VI port right? You have to buy the cable also correct?
89stangbanga is offline
Old 01-21-2010, 01:34 PM
  #103
Shimrra
Shimrra's Avatar
most good shops have a scan tool where it plugs in and when the problem arises during driving they will press a button and it will capture 30 seconds before and after the event to be diagnosed later.
this may be something that could help
Shimrra is offline
Old 01-21-2010, 01:56 PM
  #104
cholericfc
cholericfc's Avatar
The black and yellow scanner that I had a link for - in an earlier post - that one works fine, it'll blink out the codes, but it'll transcribe into actual numbers for you. You don't have to buy any kind of cable.
Old 01-21-2010, 09:32 PM
  #105
Shimrra
Shimrra's Avatar
there are a mandated set of pins in an OBD2 plug, the rest of the points are open for a manufaturer to have free reign, the thing is, each one does something difret, so if ford uses pin 4 for for something like ecu data stream, but dodge uses pin 7 for it and pin 4 is actually ABS... you need either a cable that will tell the scanner what pin is what or if you cant use one your scanner isn't much good but for basic codes.
what i was talking about does not capture codes.
it records EVERY data stream that the OBD2 port on your car is telling it, and it is mfg specific so it gets them all, so that way you have a 60 second window to see the issue in. if you cant see if in there it may be something mechanical the computer cant sense (i had a friend that threw a rod through the block with no CEL lol)
Shimrra is offline
Old 01-21-2010, 10:58 PM
  #106
cholericfc
cholericfc's Avatar
My previous response was actually intended for 89stangbanga, but I see what you mean. thanks for the info.
Old 01-22-2010, 01:01 AM
  #107
Shimrra
Shimrra's Avatar
i only bring it up because my teacher at collage is a nissan service manager, and he brought in an altama or something that was having a strange throttle issue or something and that was how they were tring to fix it becasue it was SO intermittent
Shimrra is offline
Old 01-24-2010, 05:50 PM
  #108
cholericfc
cholericfc's Avatar
I set my Timing at 13* and with the spout connector plugged in it's at 37*
I performed an Idle Setting Procedure, adjusted the holes for the TPS, and didn't get it any closer to the desired range. However, code 23 did disappear.
I performed a KOEO/KOER tests 3 times.
KOEO
22 - Manifold Absolute Pressure (MAP) or BARO sensor out of range
10 - cylinder #1 has a problem
KOER
42 - HEGO (HO2S) sensor voltage high/ system rich
92 - HEGO (HO2S) sensor voltage high/ system rich
13 - RPM at idle out of range/low (((( Idle set at 850 ))))
I went out for a test drive, 1 mile down the road to a gas station, and the car seemed fine. It went forward pretty good.
On the way back, it made one popping noise, but no matter what kind of driving I did, I couldn't get it to do it again. Car has been sitting for some time now.
At least my codes have been verified.
Old 01-24-2010, 11:17 PM
  #109
Shimrra
Shimrra's Avatar
i dont know ford codes...
HEGO?
oh wait, dur, when was the last time you replaced your o2 sensors?
it might not know the fuel trim so it is trying to guess and bolth 02's have **** the bed and are pretty much lieing to it
Shimrra is offline
Old 01-25-2010, 09:17 AM
  #110
cholericfc
cholericfc's Avatar
I was thinking of cleaning my O2 sensors, but the other things worry me. Anyone else?
Quick Reply: Power loss, hesitatation, sputter, chug
