idle problems!!! help
Old 08-17-2009, 02:59 PM
mustang90242
mustang90242's Avatar
because it acts up but then some days its perfectly fine
mustang90242 is offline
Old 08-17-2009, 03:05 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
have you tried reading the codes?
TrimDrip is offline
Old 08-17-2009, 03:08 PM
mustang90242
will it cause damage to the engine?
mustang90242
no i havent pulled the codes yet
Old 08-17-2009, 03:23 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
you need to get the leak fixed.
After a long period of time it can cause harm to you motor. You also won't pass a smog test with the rich fuel mixture at idle.
The leak is causing the car to pull in unmetered air that the maf is not reading. This can cause you to have some detonation.
If you pull the codes, you will most likely get a 41 and 91 code showing voltage to the 02sensors as lean. Probable get a code for the computer unable to maintain to idle too. An IAC code is 12.
Also, pull the IAC and clean it like mentioned above.
TrimDrip is offline
Old 08-18-2009, 10:33 PM
mustang90242
wats an IAC?
Old 08-18-2009, 10:37 PM
mustang90242
and how would i clean it? with carb cleaner or wd 40
Old 08-18-2009, 11:08 PM
19stang88
19stang88's Avatar
i heard lacquer thinner works good
19stang88 is offline
Old 08-18-2009, 11:29 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
iac is on the front of the throttle body
i use brake cleaner for about everything, carb cleaner should work.
after you clean it make sure to pull the codes again to see if it still throwing a code for the iac
TrimDrip is offline
Old 08-18-2009, 11:33 PM
mustang90242
ok thanks
Quick Reply: idle problems!!! help
