trick flow valve springs
i jus bought the top end kit from trick flow and had heard some things about their valve springs havin some problems. i jus want some input on them so that if i do need to change them i can before they go on the car.(using the trick flow cam in the kit) thanks in advance.
The springs are not the best quality, but it's easy enough to have the spring pressures checked to make sure they're compatable with your cam. I had mine checked, and had to replace them (heads were brand new) to match my cam. It's best to do it correctly the 1st time.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
