strut problem
Old 08-25-2009, 09:32 PM
ctlazersplaya07
ctlazersplaya07's Avatar
Default strut problem
so i was driving today and noticed that every time i went over a bump....when my car would return to normal height, there was a squeaking/scratching noise. i am pretty sure it is my struts....i am going to check tomorrow just to make sure....but for now i am looking at getting new struts and installing them
my first question is, not being very knowledgeable on cars (i have done my x-pipe, catback exhaust and throttle body myself so far), are struts a project i want to take on myself?
my second question is, what type of struts should i get for the car....as it is my daily driver but i do like to push it to its limits from time to time....i mean it is my baby....i like to ride her hard after a long day of work sometimes
ctlazersplaya07 is offline
Old 08-25-2009, 09:46 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
I would let someone else do them
TrimDrip is offline
Old 08-25-2009, 09:49 PM
mattdel
mattdel's Avatar
might be the struts, could also be the sway bar bushings @ the frame. the sway bar twists in the bushings when you go over bumps, etc.. eventually the bushings wear down to nothing.
struts tend to bang more than squeak. worth checking.
also i wouldn't tackle struts by yourself if you dont know how, but helping a knowledgeable friend would be fine.
mattdel is offline
Old 08-25-2009, 10:31 PM
ctlazersplaya07
so if it is my sway bar bushings how much does it cost to have them fixed?
Old 08-25-2009, 10:38 PM
mattdel
mattdel's Avatar
autozone.com lists the bushings from $14 to $54, depending on the diameter of your sway bar(they have different sizes depending on car sub-model) and brand name
about an hour of your time.
mattdel is offline
Old 08-25-2009, 10:53 PM
ctlazersplaya07
is that something i could do myself?
Old 08-25-2009, 10:58 PM
crusin92red5.0
crusin92red5.0's Avatar
the sway bar links are a easy 30min fix. struts are a little harder but its all the same basic concept,,,,,,,,,,,, PUT IT IN THE WAY IT CAME OUT.
take pics as you do it if your really concerned.
crusin92red5.0 is offline
Old 08-25-2009, 11:06 PM
mattdel
mattdel's Avatar
yes, very easily.
i'm not referring to the links, i'm talking about the bushings in the brackets.
mattdel is offline
Old 08-25-2009, 11:09 PM
mongolchuck
mongolchuck's Avatar
+1 on the taking pics. That's how i changed the blocker rings in my tranny. If you do the struts just make sure to support the lower control arm before loosening the strut. The cars weight will keep the spring in. You don't want that thing flying out.
mongolchuck is offline
Old 08-26-2009, 01:32 AM
kennebellgt
kennebellgt's Avatar
if you have an impact wrench do it yourself its pretty easy, just make sure when you have the car jacked up in the air you put it on jack stands then place the jack underneath the A-arm and jack the A-arm up until it just starts to lift the car up then stop and dont take the jack out until you have the new strut bolted all in, if you take the jack out while the strut is unbolted the spring could fly out but only if you drop it fast.
kennebellgt is offline
Quick Reply: strut problem
